Zipper89
I was given an MTD pro 1852 that was only running on one cylinder with the blades working months ago. I fixed the engine issue but now the blades won’t come on. I’m seeing if anyone knows how the PTO switch gets 12v because I cannot find it anywhere. Also the black and white wires from the clutch and dangling under the key with nowhere to plug them in. I can put 12V directly to the white wire and get the clutch to engage but the engine shuts off. It seems like a safety switch thing.
The red wire coming into the key switch has constant 12v. The only wire the gets 12v with key on is a thicker yellow wire that goes to the starter. I assumed 12v would go to the PTO switch from the key but there is none. If anyone has any idea about wiring the PTO switch or some schematic I would greatly appreciate it.
