PTO Replacement on Bad Boy ZT Zero Turn
hillro
Replacing PTO on a Bad Boy ZT zero turn Kohler engine. Question is after removing the main bolt will the pto drop down off the shaft or does it need to pulled or pried off.
Thanks in advanced.
Normally they just fall off. Sometimes you may have to lightly tap on them to get them to move.
And make sure your head is not directly underneath cause they are heavy and come off quickly ( ouch )
