We have always had a buried propane tank but are now switching to above ground.  They said they need to put in two 100-gallon tanks, up against the house.  Does anyone have experience with this?  We have about three weeks to figure out where these things are going to go.
No experience whatsoever, but here's my 2cents.
First consideration, access.   Put them where the guy can reach them to fill them, or you'll be picking another location after a cold shower:laughing:
Second, safety.   Propane is heavier than air, it accumulates in low spots so try to consider what a leak may mean should one occur. Would'nt want the stuff falling into the basement or under the house. You might not want them in direct proximity to your barbeque. Direct sunlight might also be a concern as would under a tree where leaves and debris might become difficult to remove and accumulation of same would accelorate corosion.
Third, asthetics   If the first 2 considerations leave the tanks highly visible (some may not consider 2 100 gallon tanks as the quik trip to "curb appeal") you may want to spend the next three weeks figuring out how to make these tanks look wonderful, using paint, plants, lattice or make them look like a couple of cows, hay bales, garden gnomes, or snails. Use this as an opourtunity to express your inner artistic self, the "Martha Stewart" hidden within, if you will
Fourth, removal and replacement  Are they going to have to be replaced anytime soon? Do they need to be inspected or tested regularly? If this is the case than be sure and consider this in your athesitcal design.
