Why did you do this compression test in the first place?
I wouldn't worry too much, if each of your four cylinders is reading about the same you most likely have a bad gage even though you replaced it. You go to any well known auto supply store and borrow a compression gage or better yet, your engine is running on all four cylinders, don't go looking for problems you don't have.
