I just installed a new honda gcv190 on my old snapper push mower, and it won't start. I put in the oil, put in the gas, the spark plug is installed correctly.
I turned the gas on, pulled the stop bar and pulled the starting chord while having the mower is in choke mode.
I've tried to start repeatedly, and all I get is some sputtering/firing from the spark plug but the engine won't start. Any advice would be greatly appreciated. I'm not sure whether the engine is flooded or what. I've turned the gas valve off for now.
CTM
CTM
