Check the oil level.
I suspect it will be too high & smell like fuel.
Take the plug out and spin the engine next time it locks up, make sure the plug is well out of the way and leave the brake off ( should prevent engine from sparking )
If the engine is full of fuel like I think it might be, the fuel being pushed out of the plug hole can ignite, You have been warned.
Keep records, detailed records cause this engine is sounding like a lemon and you need accurate records to make a claim.
A method that works really well is to email the dealer.
Start off with
"on advice from my legal representative I am sending you this email so there will be a detailed and accurate record of the correspondence around the mower you sold me on ........"
If they ring you, tell them to SMS or email so you will have a record.
Works like a charm most times and remember to be polite as if you were expecting what you wrote to be read out in court.
Start off with
