Primer
Ford226
I have a craftsman lawn mower with briggs and stratton engine. When i hit the primer fuel sprays out of a white nipple above what I believe to be the fuel line. Is a hose supposed to be connected to this nipple and if so where does it connect to?
Thank you for the help
No that is the air vent to the bowl.
Your carb is flooding and needs to be cleaned.
Ford226
Ok. is that why when it keeps smoking when it is running?
Ford226
So that white nipple should not have a hose connected to it?
Scrubcadet10
Moderator
Staff member
correct, i remember a similar thread, with a guy that has the same carb as yours. no hose connects to it.
your engine model # is 09P702-0177-F1
Ford226
ok it is a craftsman, briggs and stratton, 5.50 OHV, 140cc Silver edition. Model 917.374200
