K kwhittler Forum Newbie Joined Oct 13, 2015 Messages 1 Oct 13, 2015 #1 When I push in primer bulb the engine begins immediately. After running about five minutes, the engine stops. I will go to prome it again and the bulb has sucked in. The air filter is clean and the lawn mower is only a year old.
L Lawnranger Well-Known Member Joined Apr 18, 2012 Messages 671 Oct 13, 2015 #2 Read post #1 & post #3 of this thread: http://www.lawnmowerforum.com/small...7-please-post-detail-about-your-problems.html Follow the directions and you will probably get the help you are looking for.
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Messages 24,995 Oct 13, 2015 #3 The air vent into the carb bowl is blocked. Can't tellyou how to fix it because I don't know what mower & carb you have, Pity.
