My saw hasn't run for a while. The issues started when I was cutting up a fairly large hickory tree that fell. The saw started getting dieing after it got hot. Later it wouldn't start at all.
So here's what I've done and checked:
Changed the plug, fuel filter, air filter, carburetor, and ignition coil.
Low and high adjustments are about 1-1/2 turns from seated.
I occasionally get a single pop when I pull the cord.
The plug has spark, there is fuel on the plug when I take it out.
I don't have a way to check compression but it feels right.
I drained and replaced the fuel.
I pulled the fly wheel and the shear pin thing is intact.
Can anyone offer any advice?
