ttimtucker
I was given a Poulan Pro P3314 chainsaw which was sitting in a person's garage for years. It has what appears to be significant scoring on the piston as seen in this photo. I don't see scoring on the cylinder (but my only view is from the exhaust port side). Compression is 120psi. Crankcase maintains pressure/vacuum (from MityVac) just fine throughout piston travel. However it is tough to start, and near impossible to restart once warm. Carb was very clean (but sprayed passages and ran it through my ultrasonic cleaner) and diaphragms were in good shape. I know the general advice is that a machine with a scored piston will not run right. I'd like to get help from this forum to understand specifically what's going on that causes problems in a case like this, where there is a scored cylinder, yet compression and crankcase integrity look good. Does the scoring somehow affect the ingestion of fuel from the carb on the compression stroke? Or does it affect the transfer of fuel from the crankcase to the cylinder? Or the scavenging of exhaust? Or ...? Thanks for any schooling you can provide.
