Poulan pole saw always been very hard to start, getting worse
rwomack
Fairly old unit but runs good when I can get it started. Non ethanol fuel, new plug, clean air filter, new lines.
I’ve adjusted the L and H side and wide open throttle has improved. It didn’t want to run at upper rpm range before and kept cutting out.
I think my idle circuit is off. It fouled a plug trying to start it today. Is there a base line I can start from from full in? It starts easier if I squeeze the trigger a little.
