- Nov 29, 2014
- 65
- 24,995
Kev.
Are you running the wavy 3 in 1 blades on the Poulan ?
If so are you sure they are not on upside down ?
they should have "grass side" stamped into one side of the blades.
Also at the very tip there is a flute / sail / wing whatever you want to call it.
It must fact up on the mower as it is what creates the airflow that stands the blades of grass up to get cut then tosses them out the chute.
It is very very common to find them on upside down because of the mulching edge being sharp is on the back of the blade.
