hi guys, i have a prolbem. I have and older sears craftsman mower with briggs and stratton, i want to say it is and 18hp ohv engine but not sure. but anyways i can crank it fine and cut for about an 1/8 of an acre and then it starts to bogg down and backfire. then i hold down the break for a minute and it will idol back up and i can make another pass around the yard and it will do it again. i checked my spark and it is fine. I dont know if that means the magneto is ok or not. but i dont really have an idea on what is going on. could it be the points or carb or what. also i think there is a crack in the gas tank in the middle where the two halfs are put together could that be the problem. any advice would really help. thanks
