Plastic Cam Gear FD590V
Good choice! I did the same with my 345. I pulled the engine out, cleaned it up and had my friend who is a mechanic do it. He only charged me a friend rate of $100. Along with the cam/gear and gaskets I also got a water pump, oil pump gear, gov gears and the upgraded fuel pump. I also replaced the radiator hoses and flushed the radiator out.
The upgraded fuel pump has a drain hose that goes down through the frame. The original pump doesn't have a drain hose and if it fails like it did on mine it sprays fuel on the exhaust. Luckily mine didn't catch on fire :eek:
i will do the same. i replaced the antifreeze and all hoses earlier this spring. i should have done the cam swap then. oh well lol
talked to my dealer friday. labor would be 75.00 per hour for 3 hours with ME taking the engine out and taking it to them.
hello guys,
i will be doing the cam swap soon, if nothing happens. do any of you that have done this have any tips?
thanks!
