lawn mower fanatic
All I got invested in the baler is scrap lumber and time except for the hinges, bolts, and the the two latches on the door......
OK thanks for the info! It sure didn't cost you much to make! :thumbsup:
Why do you make the bales so small? Or is the baler bigger in real life instead of a photo?
Went to see a neighbor this afternoon and he gave me two tires off of the front end of a Craftsman Rider. I am going to put them on the baler so I can move it easy. :thumbsup:
Hi All
To bale pine cones you could look at vintage farm baler they used in the olden days , they are built kinda like that one you build might give you some idea top inprove the one you built they were wooden . You know they make a baler for loose straw and loose hay that is pulled behind a tractor, maybe you could find a older baler and improve and it not so big. These were built in the 60 and 70s. Just some ideas to think about good luck :licking:
Hi All
