- Sep 24, 2017
- 274
- 6,718
Put a new starter on my SRX75 today. A new solenoid as well. https://www.dbelectrical.com/produc...5-rx75-srx75-sx75-130-lawn-mower-snd0006.html
I used a DB electrical starter, and this is the first time i've had to modify one of their starters to fit. It appears the mounting holes in the starter weren't drilled straight, it'd go about half way, or a little less, on and stop.... tried the old original Denso starter, and it slid right on and off.
After making sure there were no other physical obstructions, if you looked straight down at the starter, you could tell the stud hole was angling right, while the stud (Which is straight) appeared to angle to the left,.. i knew it had to be a manufacturing defect, of some sort. Any way, i resolved the issue by using a 23/64 drill bit to drill out one mounting hole and then it slid right on. Snug with very little slop. Bolted it down, then when putting the starter solenoid back on, i somehow managed to pinch the webbing between my thumb and pointer finger with my U-Joint socket adapter.... no clue how i did it, but it hurt for a few seconds. And SOMEHOW when i was mounting the starter, i managed to crimp the batt + wire ring connector for the starter and broke it, luckily i was able to put a new end on without losing any length, got it heatshrinked and taped up.
Anyway, it cranked right up, and now i get on to replacing the spindle bearings..
