masterdrago
- Apr 14, 2020
- 2
- 5
I've discovered a leak at a connection on the pump hose on our MZ6125 zero turn mower. Parts Tree and others say it is no longer available. # is 539131532 in the book but on the hose is HTB131532POR. It looks like a tube that might be replaced with a stock hydraulic hose of the right length and routed between the pump and wheel motor. Anyone have this happen? Tightening only makes the leak worse. Split fitting? And is the fitting an SAE flare? What pressure hose?
