Parasitic draw
Illini Pete
Hey Y'all, new to this forum but not new to Cub Cadets. My problem is with an LT1050, probably around 20+ years old, hadn't run for 4 or 5 years, so wanted to get her back on the yard. New battery and new starter solenoid and when I went to hook up the neg battery cable, got a spark, with key off. Pulled ignition switch and checked all poles with key in all positions and all checked out OK. Cleaned all socket plugs I could get at and still have a circuit open somewhere. Removed cable attached to starter and no longer a spark when I touched neg ground cable to neg battery terminal. Removed starter motor and bench tested it and all worked fine. Any suggestions on how to proceed?
Thanks!
Illini Pete
If it's a remote solenoid, it's often a more accessible connection than at the starter. 2 big wires at solenoid, 1 is battery, 1 is starter.
The solenoid is bolted to the bottom of the battery shelf/tray and the terminals are not reachable without removing the battery and the tray mounting bolts
