Owner
Monandsteve
Scag / tiger cub. Blades keep shutting off. Battery (new) keeps going dead.
With the engine running check the voltage at the battery terminals. Should be around 13.5 if everything is working properly. If below 12.7-13 then time to start checking for why the charging system isn't working. Also make sure the battery isn't faulty, even though it is a new battery.
