random.minnesota
Okay, so DIY usually comes naturally but I have no experience with engines and I've exhausted the standard YouTube and Google searches. Thought I made progress but my mower still won't turn over.
Make: Yard Machine
Model: 11A-41MB029, 139CC OHV 21"
Already have done:
1. Emptied the gas and refilled
2. New spark plug (and confirmed it was creating a spark).
3. Removed air filter (even though it was clean, I left it off to make sure there would be plenty of air flow)
4. Pulled the fuel line and let gas run out of the tank through fuel filter to make sure it wasn't clogged
5. Blew out and used pipe cleaner on the fuel line from tank to the carb.
6. dropped the bowl on the carb and wiped out
7. Blew out the entire carb assembly with compressed air
8. Found out that the float needle was sticking so I pulled and cleaned, got excited thinking I finally solved it (NOPE!)
9. New oil
10. Pretty sure gas is getting from carb to the combustion chamber because when I take off the plate on the front there is new fuel on the bottom (I had wiped this out when I started).
So...What can I do next? Thanks.
Make: Yard Machine
Already have done:
9. New oil
