MowerMark
- Mar 1, 2014
- 57
- 287
For over ten years my garden has enjoyed automatic sprinklers. Four years ago the controller was changed to an Orbit six channel with remote control. Love it. About two years ago channel four had poor flow. Strange. The valve was fully open. Changed the valve converter & solenoid and the flow was fine. A month ago channel six, not four, which for many years had excellent flow through seven small sprinklers with good grass coverage, developed the new onset of slow flow to all seven half circle and quarter circle sprinklers.
Today the valve and solenoid were changed from an Irritrol 3/4 inch to Orbit (3/4 inch, Model 57029) and despite the new valve being fully open, the slow flow is still evident.
The only troubleshooting step about which I can think is to cap off the seven 1/2" risers and see if there's any flow whatsoever. If there is, there's an underground leak. The old and new valves should not both be malfunctioning. Maybe all seven pop-ups have some debris at the nozzles.
Could the slow flow be the back flow relief valve (or whatever that piece is called) ? That piece and insides were not changed. I did remove the cap and put it back on loosely, then activated the solenoid, let water flow out, then tightened it.
Any other suggestions to fix this ?
