gokart
- Aug 7, 2021
- 1
- 1
would like to put a timer on my 5hp Honda water pump . Have a late night water schedule ,and have been just letting the gas run out ,but don't like the pump recycling when running out of gas. Does have an on off switch that I could wire up to timer . The on off switch is hooked up to the low oil sensor so I have to look at it closer ..The timer when tripped ( 0 min) would have to have a closed circuit ( conductive to ground) Any ideas would be appreciated .. need my sleep ? thk/u. gus.
