Hey, I've got an old murray pushmower with the classic briggs engine and the fuel tank with the plastic carb on top and the pulsa primer button thing. Last time I had an issue with the primer not sucking in fuel there was a small hole in the primer bulb which I replaced so this time I am having the problem I just replaced the primer bulb which didn't help. What are other reasons the primer bulb wouldn't be sucking in fuel? Do I need to replace the carb diaphragm? That two piece part no. 795083 gasket looking thing? I took everything apart and cleaned it with carb cleaner just hoping that when it all went back together it would work but it is not. I'm thinking I just should go ahead and replace the diaphragm but wondering what else I could do to troubleshoot this. THx!
