Sawfxr
- Apr 20, 2012
- 3
- 10
I picked up a small tiller that has an old Briggs Mod# 80102 2.5 HP motor on it. The tank mounts directly to the underside of the carb and there is a plastic tube that I believe is the fuel pick up. It's cracked about half an inch below the surface of the carb which allows air into the carb and causes it to run bad. How do you remove that fuel tube to replace it?
Thanks
E.
Thanks
E.
