Skippydiesel
- Nov 29, 2020
- 13
- 261
Yes! I realise this topic may have been discussed to death already but recommendations seem to change over time so I thought why not give it another go.
I live in Australia - climate range can go from 0C (rarely) - 47C (also rare). Mowing range mostly 21- 40C (grass growing).
In my small engines - push mowers/pumps/generator/ compressor, older ride on (B & S 17 hp) I use a straight, single grade, mineral oil W30 - never had a problem.
Put a new Kawasaki 22hp in my commercial zero turn - Mower shop recommended I use a semi synthetic 10W-40 with Zinc. Kawasaki manual says I can use the 10W- 30 or 40 OR the straight W30 BUT advises that fuel consumption will go up with the multigrade oils.
I am happy to put a semi synthetic multigrade in my "Kwaka" IF there a real benefit, otherwise will use the W30.
What is your advice?
