I am helping a friend on his riding mower with a B&S Power Built 500 cc Engine. He said it was running poorly and was smoking.
This is what I found.
Spark plug was loose and sooty
Battery cables were loose
One bolt on the valve cover was missing (broken off) and oil was leaking out and dripping on the muffler
The valve lash was in spec.
I removed the head and inspected it. The head gasket seemed ok. It is original. The head was sooty. The push rod chamber seemed relatively cleab. It did not appear the gasket was leaking in there. The bottom of the cylinder was slightly scored.
I need to check the head for flatness. If it is off a bit what can be gotten away with. Is there a thicker gasket available to make up for some warp? I am thinking ahead in case it is off a lot.
I never saw it run. I assume there is some higher oil burning. Probably livable. The smoke he observed is likely mostly from the oil dripping down on to the muffler from the valve cover.
What is causing the oil to turn grey? Is it all exhaust blowing by the rings? He has been using SAE30 and changed the oil every year. He has not changed it this season yet. I am thinking to change the head gasket, fix the broken bolt and put a gasket on the valve cover. New plug and oil change. I would put in 10w-30 and change it after 1 hour to make sure all of the grey oil is oil. Then put in 15w-50 synthetic. I have read it burns less. Not sure if that is practically true?
A leak down test would be good but don't have one.
He said it ran with reduced power but good enough to mow his lawn. Even with a loose spark plug. I was amazed. He can not spend a lot of money right now. He just wants to keep it going good enough.
Thoughts?
Thoughts?
