Oil filter
Pinky56
I am work on my moms mower. It has a powermore engine. It takes a Arnold 751-12690 oil filter. I'm try to find a cross reference chart to find a cheaper filter. Thanks for any help.
I suspect since there limited number of the Powermore engines with an oil filter out there being used by customers, there may not be enough demand for an aftermarket company to produce them.
If it's a spin on and you can...Look at your local offerings to obtain a filter with the same threads, rubber seal diameter (mates to block) and length. BTW many on this forum suggest cheaper is not better, only penny wise foolish.
