Don't believe,not sure is the correct answer. Briggs idea is the new engines are manufactured with tighter tolerances, and the distance between the full and the add mark is 20% of the oil volume. They claim that volume is all this is needed to replenish the additives in the remaining oil. The other catch to this is the air filter and spark have to be serviced on a regular basis.
The push mower engines are designed to operate like this for the expected life of 125 hours which for the average user is 10-12 years. You can change it if you want, by making sure the fuel is drained from the system, and then turn the mower on its side to drain the oil out the fill tube, and then refill with the recommended oil of your choice.
