I have 12.5 B&S engine and when I start it, it runs ok but after it runs for 2-3 mintues it will shut off. take air cleaner off start it run ok but before it shuts off gas and oil come shooting out from where air cleaner goes on. Took carb off and in back of carb there is like a air box that has a tube going to the carb, removed that and you can see the valves and that area was full of gas and oil. what would cause this to happen?
