OHV Snow King starts and dies?
sam.caruth
I have a Tecumseh Snow King on my snow blower. It ran perfectly fine until about 1/2 way through last season. I went to start it one day, and it ran for 3 seconds, and died. It would start over and over, but always dying after about 3 seconds. I thought it was just a gas issue, so I looked at the carb. Nothing looked to be plugged up. I then Noticed the OHV hose was cracked and completely fallen apart, not connected to anything. Could a bad OHV hose cause this? Thanks.
Lawnboy18
What do you mean by OHV hose?
reynoldston
I am going to guess by what you call a OHV hose as being the crankcase vent. It really shouldn't effect the running of the engine but it might leak some oil. It sound more like a fuel problem.
Take the carb off and remove the float bowl. Tip the carb upside down and look to see if the float is level. I'll bet that the side opposite the hinge pin is higher. If it is I would follow this procedure and replace the float needle and seat with kit number 631021B. We're getting snowblowers ready around here and I do at least one of these carb rebuilds a day.
Needle and seat replacement
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. *Next check to make sure that the float does not have any liquid in it. *If it does, replace. *If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: *On the side of some Tecumseh carbs you will find a plastic cover. *Under this cover will be an idle jet. *Remove it and check to see that the jet is open both horizontally and vertically. *You should be able to push the old float needle wire through the vertical opening.
primerbulb120
Moderator
You can also replace the carb for $25 if you would rather not adjust or rebuild it.
sam.caruth
Well guys, I finally got around to pulling the carb. Got it pulled and the float didn't stick at all, and was very easily moved. There was a good deal of dirt particles and grime at the bottom of the bowl. Got it soaking now. I will resemble and fire it up tomorrow. Ill let you know how it goes.
sam.caruth
Well guys, got it all put back together and on the blower. The primer bulb is only pumping air. I have no clue why. I can't get it to start at all now. I spray some starting fluid into the cylinder, and can get it to start. Any help would be great.
Are you sure you have fuel in the carb bowl? Loosen the bottom bolt and see if fuel starts to flow out. Also, take the primer line off the carb, pinch it off and push the primer bulb. If you don't feel resistance, the bulb or line may be cracked.
