OHV head gasket failures
Thorogood
My 33 series engine keeps blowing head gaskets. Have been replacing these for years in many engines and they never came back. Could the head be warped?
Good Question. Are you using the current torque specs of 21 ft-lbs. and Using three torque and proper screw tightening sequence? can't torque to full torque right off the bat, surely will warp the head.
Amazon (no control over picture size). Mechanics Straight edge, and feeler gauge. The feeler gauge shown is .005", I'd look for one that is .001" or .002" as the smallest size.
and
Have the tins been removed from the cylinders for easier access to clean them and then left off? I have seen that happen a few times. The tins must be in place for efficient cooling air flow from the top cover and flywheel fan.
The heads also need to be resurfaced by using some 400-grit sandpaper on a true flat surface such as tempered plate glass to achieve a true level surface.
Every head I've pulled was/has been warped.
Yes your head AND block area where the head sits needs LAPPED. Lapped meaning flat and clean.
Yes you need a NEW head gasket.
Wouldn't hurt to spray some high tack sealant spray ON the head gasket both sides.
Wouldn't hurt to chase the thread holes with a tap while you are there.
Nice to clean the head bolt threads with a die.
Wouldn't hurt cleaning the cooling fins ALL AROUND the cylinder/s. If yours has that tin that directs cooling air around the cylinder/s, needs to come off and clean under and all around it.
Nice to spray the bolt threads with brake cleaner, shop air and SAFETY GLASSES. Keep the threads dry as in NO oil on the threads. Oiling the threads lowers required torque.
As others mentioned, proper torque is good. Mow a couple times and recheck torque.
I must be jinxed here in South Texas. I see warped heads and blown out head gasket on a fairly regular basis. What is even worse are the ones that raise the valve guides up out of the castings or the intake valves set stuck in the guides due to contaminated or expired gasoline.
I don't think I have ever found a Kohler Command head warped less than .007 and the Briggs Intek less than .010.
