I have a Ferris IS700Z. I've had it for 4 years and put about 211 hours. Today there was an odd sound that started happening. This is the first time I've heard it.
It's not the typical squeaking/squealing whenever I need to lubricate. It happens with or without blades being engaged.
Last week I was mowing taller grass and ran over tree stump sticking out if the ground just a little too high. I usually manage to avoid it.
I took a recording of it. Below is the link. You'll have to replace the (dot) with a period.
It's in Google Drive and I believe I have it set to share properly but let me know if not. Thanks.
drive.google(dot)com/file/d/19qSXCEvSoclDnc4hYlXp_sIBKPCN7Z5z/view?usp=drivesdk
