Folks:
If you watch this clip I uploaded you will hear a hissing sound when the blade is not engaged. When blade runs it is much harder to hear. It is almost as if a bearing from the crank to the drive line is dry....if you will. The engine has normal compression sounds, but the motor is drowned out by this rushing sound. I fear I may have done something wrong to cause this.
Quick backstory -
I replaced the drive belt and blades with OEM items. Also replaced the carburetor and gaskets as my OEM carburetor was leaking fuel. In fact, it leaked fuel into the piston at sitting as when I would start it it would blow fuel out the exhaust, and a little oil. I change the oil after replacing the carb and all those issues are gone. It has new, clean oil and at the right level. However, it has this odd sound.
I mowed today with it and all went well. I just worry that either I did something wrong in assembly or perhaps worse there is a larger engine issue. I do recall that I over filled it with oil and ran it a few cycles that way. I since drained it but do wonder if all of this could be causing an issue with the OHC and oil that is pumped to the OHC. This noise isn't as if it has noisy lifter, but to be honest, I'm familiar with Honda car engines and over head cams, etc. I don't really know how this cam system works nor if it even gets oil to the head via a tube/conduit.
Any thoughts what would cause this noise? It starts on 1st pull, doesn't knock, has normal idle. Just worried about that sound.
By the way, engine model is the GCV160A0 and this is a Harmony HRR2167VXA.
LINK to video --> https://youtu.be/gxxwJMwAX2o
Quick backstory -
