Obsolete SCAG Idler arm assembly #46145
That does not look like a steel bushing,it looks like the top of the bronze bushing.What is the condition of the idler support shaft?
You can mike the shaft and hole where it is not worn and order bushing accordingly.Send me the dimensions and I will try to find a bushing for you.Heavy duty industrial bushing are far superior to the ones used on mowers,and if I know the dimensions I might be able to help you.
Hi lowmow,
Good point about the receiving idler shaft. Yes it is also worn out and I knew it upfront. I have a new one on order. This one is still available at Scag. I am good now. Everything I need is already received or in transit. I did not need to machine or customize anything but I will keep your offer in mind. This mower is 34 year old. I will keep it until the engine or the hydraulics gets beyond repair.
Thank you much.
Richard
Hi all,
I need to replace a worn out idler arm for my 52" Scag walk behind SWZ-14KA built in 1990.
The hub portion has been damaged by letting the bronze bushing wear out very badly.
Problem is: The part needed is the 46145 but it is no longer available at Scag and they do not provide any alternate idler arm to use.
So I am sending this message to see if anyone may have this arm assembly to sell. Used or new.
Please let me know if you have this part on hand or know another source.
Any help will be greatly appreciated.
Thanks so much.
Richard
My distributor shows 6 in stock.
Hi all,
Thanks so much.
Richard
Jacks small engine has it on the website.
Hi all,
Thanks so much.
Richard
Jacks small engines website says they have it.
Hi all,
Thanks so much.
Richard
Take what’s left to a custom fabricator or weld shop. They can craft you what you need.
I got the arm from Ebay. Just not sure about this part availability from the manufacturer.. I was told it is discontinued.
Anyway it is wise to ask the store you deal with before you place an order.
