not enough power
pas
My laxer ct is not running like it should i use to be able to mow through tall grass no problem.it started dieing when blades are engaed.even when hot have to choke it to start.new filters drain fuel
It sounds like you have a 2 cylinder engine only running on one cylinder. When you first start it up see if both exhaust pipes get hot.
