P pas Forum Newbie May 12, 2016 #1 My laxer ct is not running like it should i use to be able to mow through tall grass no problem.it started dieing when blades are engaed.even when hot have to choke it to start.new filters drain fuel
reynoldston Lawn Pro May 12, 2016 #2 It sounds like you have a 2 cylinder engine only running on one cylinder. When you first start it up see if both exhaust pipes get hot.
