Friends, is there a device that can reduce noise from the grass trimmers? This handheld machine has a high pitch sound. Many neighbors feel that the noise punctures their ears
#2
Two-Stroke
Here in Atlanta, strippers work in loud, smoke-filled nightclubs -- I can't imagine how anyone could hope to keep them quiet.:biggrin:
My apologies. I didn't mean strippers at all :ashamed: I meant grass trimmers. What was I thinking when I said strippers? Maybe I didn't look at the dictionary very closely.
To be sure, I meant this . . .
P.S. I have edited the first post to avoid confusion and before someone would post a different picture here.
Does it produce so much noise to warrant noise manufacturer? If your neighbors have not yet complained, maybe you should still hang in there. A mower is not supposed to be quiet after all.
#7
lizard
Buy a quiet whipper Snipper like a Kawasaki KBL 27C...........nice quiet 2 stroke.
Cheap and nasty Whipper Snippers are generally very noisy...........so thats the story.
#8
dusty-t
I don't do any trimming. Either my son or my son in law do all the trimming. One thing I have noticed is that my son who has not used a trimmer that much revs it up quite a bit to trim. My son in law barely brings it off of an idle and trims just as fast but with a lot less noise. Mind you he has been doing it for years.:biggrin::biggrin: Dusty
#9
be cautious about running the trimmer at half throttle because two strokes are only fuel tuned properly at idle and full throttle and may cause a lean condition at mid throttle leading to catastrophic engine failure.
I can't bring myself to get one of those trimmer things because of all the noise. I live out in the country because I like peace and quiet. If they invented a quiet one, I would reconsider.
Good point sir, hehe. Maybe I am the one complaining. It's my neighbor that does the grass trimming. Lawns here are not flat so we use trimmer, especially in corners. I like quiet. But yes, other neighbors are OK with it. But also maybe the quality of engine is not good. Neighbor is a friend. We talk.
#13
One of the manufacturers of gas concrete cutoff saws was having problems with engine failure at a certain. contractor. Come to find out they where running them at half throttle cutting plastic pvc pipe. the saw runs lean at half throttle (carbs are not set up with a intermediate fuel flow) and the slower operating speed lead to overheating.
That's not good, huh? Why they run in half-throttle? Why not full? Just wondering. I don't know much about cutoff saws. But they are also handheld like the grass trimmers, right?
The implication is that the people operating the saws didn't know what they were doing.
I can think of another reason not to go under load at less than full throttle [applicable to chainsaws]: the saw will be more likely to grab or kick back if the chain is spinning slowly -- always bring a chainsaw engine to full speed before beginning to cut.
Wow that is SO true... I have seen the results of folks that have had bad experiences with kick back... very nasty... KennyV
#17
lizard
Buy cheap rubbish and you get a lot of Noise,,,,,,Buy Quality.......check the noise levels ........only a Fool would operate a noisy Whipper Snipper.......the Fine is Extreme in Australia......wake up.
Your Neighbour will not be Happy.........and how could you not blame them........you are destroying their quality of life
My echo is so much quieter than my old home light i also had a "weed eater" brand also very noisy very annoying to use will give you a headache after a few minutes. My echo is so much more powerful holds better string and is extremly more quiet at least in higher decibles it can still get pretty loud but still.
