No start zero turn Kohler 7000
shadowvampyre
Craftsman Z6600. Kohler 7000 24 HP. I was mowing, and the left side of my deck caught a landscape stone circle around my flagpole, and the blades stopped turning. I drove a bit playing with the PTO, and they wouldn't start spinning. I stopped the mower to take a look at belt.
Belt was fine. The mower won't start or even turn over now. was running fine except those blades. What might cause it to not start after that deck hit?
Recently put in a new starter and starter solonoid. Charged up the battery, multimeter is saying 12.4 V. With the key in, the hour meter isn't even lighting up. When I try to start there is very faint click coming from the engine side, like probably the driver side of the engine towards the back. The battery is maybe a year old I would guess from memory.
Can someone please help, I am stumped with long grass too
First thing I would check is to make sure you pressed the PTO button back down.
Check belts, make sure you didn't break a belt, make sure blades turn freely. If you turn on the key and engage pto. Do you hear a click/thump?
Belts are fine. Pushing or pulling PTO doesn’t do anything.
There is a quiet click near the back end the engine when I turn the key
Check the PTO fuse and all the fuses. Could be the PTO switch as the start circuit goes through the PTO switch. The faint click you are earing is probably the fuel solenoid in the carburetor.
Recheck your battery installation and clean the cable ends a battery posts. New batteries often have a gray oxidation on the posts.
sounds like low voltage and the starter solenoid is chattering
Is the starter solo pod at the rear of this engine. It doesn’t sound like it’s coming from starter on the side or the starter relay. Both are new as of August
