- Nov 29, 2014
- Threads
- 64
- 24,729
I can not access the craftsman site from Australia as it is geographically excluded.
The basic wiring will be battery power wire at the key switch to the S ( for start ) terminal on the key switch then to the PTo safety switch then to the parking brake switch and if it is a manual box to the neutral switch on the box then down the the solenoid.
The batery wire to the key switch is usually full red & will have a fuse in it.
Usually iit is connected to the hot side of the solenoid battery cable ( saves wire )
All of the switches will be NO 9 closed circuit when plunger depressed
so that makes it easy as all you need to do is jump the 2 wires at each switch
If the parking brake has 4 wires then they jump flat to flat one side needs to be jumped to crank the engine, the other side needs to be open to turn the magneto on so you can jump both sides to start with and see which pair will cause the engine to crank
