No start, no current to white wire on solenoid
Keith B
I am hoping someone may have solution for this. I am proud to own my late father's old (mid to late 1980's?) Craftsman LawnRider, #model 917.256322, serial #0931S02493. It has always been very well maintained and stored indoors. When I tried to start it for this first time this season, I have fully charged battery, and when I turn the key, nothing. No clicking, no noise, nothing. I used jumper cable and connected positive post on the battery to the red post on the starter, and then the starter turns over. I really need to start it with the key. The white wire going into the solenoid has no current going to it. There are no breaks in the wires. Yes, I have current coming out of the white wire that exits the ignition switch. The two white wires on the clutch safety switch, and the two wires on the PTO safety switch, have NO current. Should I also be looking at the seat switch? I did hold the spring-activated metal plate that is under my seat, in the "there is a person sitting here" position with some tools, and I then tested for current in the two wires going into the wiring harness that enters that metal spring plate, and there is no current for both of those wires. The starter motor is fine, and I don't think the solenoid is bad, either. Any ideas? Most people I know would approach this as "oh well, time to buy a new tractor". I am not from that school of thought (or that tax bracket). This is a perfectly good machine that has been highly maintained and pampered, it simply needs a diagnosis on what likely is a $15 part.
Telesis
First, the seat switch has nothing to do with the starting circuit. The seat switch is used in conjunction with the PTO switch to shut the mower off when A) the engine is running + B) the PTO is engaged or on + C) the operator gets off the tractor. When that happens, the ignition unit is grounded and the tractor is 'killed'. That's why you can get off the tractor as long as the PTO is off.
For the starting circuit, I looked at the wiring diagram for a tractor of similar vintage. I could not find your exact manual but I'm very confident it's the same. BTW, you are measuring Voltage, not Current. There are 3 things in series, as you've observed, before you get to the solenoid. Battery voltage goes thru the ignition switch, then to the clutch/brake pedal switch, then to the PTO switch, then to the solenoid, in that order. So, with your meter set to measure 12VDC, start at the ignition switch. You said you did that and you are seeing 12V when the Ign key is turned to start(at the white wire). Your black lead is touching a good ground at the frame or battery (-) post. Next, go to the clutch/brake pedal switch. With the brake set, you should measure 12V on BOTH sides of the switch. If you only have it on one side, then this switch is your problem. Since you said you didn't measure anything on either side of the connector, it appears the fault is between the Ign switch and this switch.
For completeness sake I'll finish the circuit testing. If you have 12V on both sides of the brake switch, go to the PTO switch. It will have 4 connections. Two are connected when the switch is off(likely white wires), and two are connected when it's on(likely black wires). The two that are connected when the switch is OFF are the ones you are interested in. With the PTO OFF, just like the brake switch you should have 12V on both white wires(I'm assuming both are white. I know at least the one going to the solenoid is white) If you do have voltage on both sides, and you do not have it right at the solenoid when you remove the white wire and measure, then the problem is the wire in between. If you only have 12V on one side of the PTO and not the other, the PTO switch is bad.
So, based on what you described, you did NOT measure 12V on either side of the clutch/brake switch. You need to trace the wire from the Ign switch to this switch. You can disconnect both ends and use the Ohms function of your meter to check the wire itself and verify if it's open(infinite ohms) or OK (very low ohms).
Take a few more measurements and let us know what you find.
Boobala
If there's a fuse in your harness ...check that too!
Keith B
Telesis, thanks so much for this fantastic series of instructions. Last night, I did measure voltage to both of the white wires on the Cluth/Brake Switch, and the two white wires on the PTO Switch (you are correct, my PTO has two white wires and two black wires). Both white wires on both of those switches showed no DC Voltage. When checking for this voltage, I know the key must be in the "on" position. But does the key have to be rotated all the way, to the actual last "start motor" click? I did it both ways, and I still got no voltage on both of those switches. Just want to make like easier tonight, in case I don't have to hold the key in that last "start motor" position, as I plan to poke around with it again tonight. I will also try to disconnect both ends of wiring and check Ohms measurement - thanks for that suggestion! So when I disconnect the wire and measure both ends of the white wire, do I simply touch red multimeter lead to one end of the wire, and black multimeter lead to the other end of the wire? If the wire is good, will that be infinite ohm or very low ohms. At my age I should know this, but I am not experienced with electrical.
Johnmcnulty
I have a Hayter 13/30 which has no power through the small wire to the solenoid (if I connect to the battery directly it operates the connection). There is a good 12volt connection to the main solenoid wire. The earth is also good.
I replaced the ignition switch. There is continuity from the ignition switch to the lights but they do not come on with the key. I checked the PTO and brake switches, they work properly, there is continuity from those connecting wires to the battery earth, as there is with the seat safety switch. The fuse is good.
If I try shorting the solenoid across the top the engine started a couple of times, now it turns over but doesn't want to get going.
As the problem started with the solenoid not getting power through the small wire (white on some machines) I checked the new ignition key and I am getting continuity between the battery and starter posts.
Any advice would be much appreciated, this is driving me nuts! Thanks!
shiftsuper175607
John
It gets very confusing trying to fix two problems on one thread.
Start your own problem thread with all the info and you should get the help you need.
Well you know your problem, no power to the trigger wire on the solenoid.
Follow it back through the harness, checking for 12 V either side of all the switches you come across till you find the faulty one.
You will find it easier if you pull the plug from the key switch & jump the B & S positions, be very careful that you get it right cause if you jump anything to the M terminal you will fry the magneto.
Jumping the B = Battery ( power in ) to the S = Solenoid ( power out to your white wire ) will leave both hands free to test the switches, both side till the dud one is found.
PIA but there is no quick & easy way to do it.
Johnmcnulty
Thanks I'll give that a try!
Johnmcnulty
John
Sorry about that, the re-post related to checking the switches, John
Johnmcnulty
I tried that and had power coming through the switches to the small orange wire on the solenoid.
I bypassed the switches just to check and same thing.
I am getting 12.4 volts to the small wire when I crank the ignition switch. I have a continuity to the battery earth from the solenoid.
The solenoid activates if I take it off and connect it directly to the battery.
The switch shows continuity between B and S when I turn the key to crank.
I'm not getting lights on either, any more ideas would be great, Thanks!
