no stablizer carb??
qualetale
Have a cratfsman (briggs/Stratton) mower. Carb destroyed twice on first mow because no stabilizer used. Can I switch the carb to one that doesn't need stabilizer? How would carb be identified to know difference?
thanks
brand new mower. Sears instructions "MUST USE STABILIZOR". they fixed once but wont fix again so trying to get back to a "normal" carb
Yout mower used 5/8 th of SFA fuel, so buy premium grade ethanol free fuel.
Put a fuel tap in the fuel line between the fuel tank and the fuel filter, makes it easier to replace the filters.
Turn the fuel tap off and allow the mower to run dry every time you will not be using it or more then a week.
Neither of your carbs were "Destroyed" they were simply gummed up & needed to be cleaned.
Sears is giving you a line of BS. In the few years I have worked on engines, I have never seen a carb that must use stabilizer. As said, clean the carb, and replace the float needle and seat. Also, as said use nonethenal dual if possible. Here is a procedure I follow.
Needle and seat replacement
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. *Next check to make sure that the float does not have any liquid in it. *If it does, replace. *If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: *On the side of some Tecumseh carbs you will find a plastic cover. *Under this cover will be an idle jet. *Remove it and check to see that the jet is open both horizontally and vertically. *You should be able to push the old float needle wire through the vertical opening.
