Should I get enough fuel digging in there from a few pulls of the rope?
It starts with carb cleaner but won't keep going and I'm not able to get a Q-tip wet.
I gave it a quick cleaning, used a wire in all the holes I could poke and cleaned the bowl and the needle jet which I assume works since it's not overflowing into the carb throat right?
I confirmed I got fuel to the bowl.
What would be the most likely culprit here blocking fuel to carb throat? Also I just installed a new primer bulb and I can't pull anything but air from it. Not sure what that means
