Nikki carbs
CLStout
Thanks. I did make sure that it was listed for that particular engine. And yes, mine is a single cable control.
Then you have the wrong carb
The work around is to get a small weak tension spring then drill a hole in the choke plate on top of the carb on the opposite side to the control wire ( might be one there already ) then pop the spring on there to open the choke when the cable backs off
CLStout
I wonder if it might be easier to just ask for an exchange? Or, just in case, where might I get my hands on some small springs like that?
Most hardwear stores or auto parts stores or engineering supply stores will have an assortment rack of small tension springs
