Convert
- Jan 24, 2020
- Threads
- 5
- 28
I run NGK BP6ES plugs in my 1976 Moto Guzzi Convert motorcycle. Engine looks and operates the same as my Kawasaki FH641v, both engines are 90 degree V twins, the only difference is the layout.
The Guzzi engine/ bike ( 67000 miles) the crank is horizontal while the Kawasaki (575 Hours) is vertical shaft. Actually they are cousins as far as design goes
What I'm getting at is both of these engines are aircooled, run at high load, and both use NGK plugs without issues,
with other plugs (mfg) not so much
TOMB
TOMB
