Newer carbs now have an adjustment?
JBtoro
I am looking to buy a new carb for my GCV190. To my surprise, I noticed that many (all?) now have a Pilot Screw. I have not bought a new machine of any type in over a decade so none of my Honda carbs have this. I suppose this allows for some adjustment but not sure what exactly, RPM's maybe? Any explanation will be much appreciated.
Hammermechanicman
I don't think that is an adjustment screw. It just covers the pilot jet.
Scrubcadet10
Moderator
Staff member
i thought so too, but then i found this pic, generally the pilot jet is under that other flat head screw below the RPM stopper.
Hammermechanicman
Yeah, looks like you're right. Not seen a chonda carb with that screw on the side
you will probably find it is the carb for an engine that is sold in Asia that some one got a shipment of & is selling them on evilpay or Amazone where apparently EPA regulations don't apply .
Down here no new 2 strokes using a mix heavier than 40:1 can be sold in a shop.
Ebay has hundreds of old 25:1 two strokes for sale and if the stats are correct some of the models have sold near 1000 of them .
I , as a registered repairer can't buy the tools for adjusting any carb latter than a Tier I from my wholesalers but Amazone Aust sells kits for Tier II & Tier III to anyone
Born2Mow
• Running engines need to meet emission specs. Individual parts do not.
• Every carb I've even seen had adjustments. It's just that the manufacturer has to hide them from the owner to meet EPA specs. This is usually done with a lead plug (or some such hiding mechanism) once the factory adjusts the settings.
JBtoro
Thanks for the background. But what does the adjustment actually do?
Born2Mow
That totally depends upon the design of the carb. In the photos above it appears to be a idle mixture. Some carbs also have a variable main jet screw.
JBtoro
Hmm, evidently nobody here has actually bought one of these carbs & adjusted it by turning that screw. I posted at another forum as well & got no responses. Yet, Amazon & ebay have dozens of offerings so people like us are obviously buying this style carb. Just saying.
