New to forum - looking for hydro-gear experts
Ch_in_tn
New to the forum. I have a hustler raptor SD 54 inch, had to replace transmission, the new one is not exactly the same as my old one, but it is the current and correct model for the Hustler part referenced it the parts diagram. Hoping to find some resources on here to help, will post details later when I get privileges.
What is your question (s)?
Hyrdo-Gear has superseded my original transmission model. The Hustler part number now cross references to ZH-MCBB-SEMC-3PXX. The only letter difference from my original transmission is the 'S' in the new part number. According to Hydro-Gear's magic decoder ring in the service manual, that number change applies to "Brake arm and style". However, the new transmission arrived with a different oil fill/overflow configuration than my original.
My original had ony a single threaded port on top of the aluminum casting, which had a right-angle barbed fitting which has a 1/2" hose routed up to my oil expansion tank mounted under the seat. The new transmission has two threaded ports. The port where my old one had the hose barb fitting had a yellow plastic plug. Right next to that is a large Hex head plug for unknown purposes. Several google and AI searches suggest that this transmission has an internal expansion tank, but I cannot confirm that and Hydro-Gear has been unresponsive to my requests for answers. Other sources said that it does not. One source suggested that if it has an internal expansion tank, if I connect my original hose/expansion tank, I risk overfill and blowing internal seals, etc. Several sources said I am to pre-fill the units with oil, and install some type of breather fitting on the port where I installed my hose-barb.
I paid almost $1,000 for these new transmissions and I don't want to kill them by installing them wrong. I'm pretty handy with a wrench but nobody seems to be able to tell me with authority how it should be configured.
I'll try to attach photos of old and new.
The two plug configuration suggest internal expansion tank, but the parts diagrams doesn't show it for that unit. Could you post the actual 6 digit model number for your mower as well as the alphabet soup model number from the old hydro.
Hi, and many thanks for the reply.
Model number and S/N is shown below. Model is 938670, original transmission number is ZH-MCBB-3EMC-3PXX.
According to the Hustler parts list for my model, the transmissions are part number 604708 (Right) and 604709. Every online resource agrees that the stated Hydro-Gear number I posted above is the correct cross-reference for this Hustler part number.
The attached photos are directly from my frame/transmission as installed.
According to Hydro-Gear's model identification table:
CharacterValueAttribute
1ZTransmission series
2HReduction ratio and pinion material
3MAxle side and charge pump rotation
4CAxle end, studs and length
5BCheck valve configuration and input axis
6BCheck valve configuration
73 → SBrake arm and style
8EBrake arm side, rotation and position
9MControl side and type
10CControl arm
113Bypass arm
12PFan and pulley kit
13XBreather fittings
14XReserved
