This warning is validThis is my favorite kind of problem: cut two wires, crimp.
Yes I really like it when some one cuts a 4 wire seat switch , joins all the wires together and burns out the magneto coils
This bit contains the wrong part number, I would have put the right one there but have been unable to locate it .
The Ultima uses the 725-04363 switch which is a standard 4 pin NO/NC interlock switch WRONG INFORMATION
Wired up so the switch can not simply be unplugged nor shorted .
The important question is did the new seat come with a switch already installed or did you have to swap the one from the old seat over.
THESE LINES DELETED BECAUSE IT WAS INCORRECT & THUS CONFUSING
The wiring diagram is in the owners manual which by law had to be supplied to you with the mower.
Cub for some reason are limiting the information available on line
WELL I have to admit defeat on this one
Star is correct the part number above is for the lap bar switches
I saw the words "Seat Switch " under the number 3 but did not notice the "to" or "the arrow pointing to the plug" but should have noticed the fact that there were 2 number 3's in the digram so it could not have been a seat switch as there is only one of them .
OTOH the seat switch is not listed on the electrical system page and I have gone to the effort of checking every diagram for the 42" version 2018. 2019 & 2020 but could not find a seat switch listed anywhere .
SO I have no idea where Cub hid the seat switch part number but I could not find it which is vary annoying as I am here to lear stuff like every one else.
