Well had the CC dealer over today and he brought the RZT S42 tractor with him. He looked at the big hill and was a little concerned. He took it out and was able to run up and down and around the slope without a problem. I drove it a couple of times as well and while I felt comfortable on it I could tell it would be difficult to maneuver the unit and 42 inch deck with all my beds and yard undulations. I could see the deck always trying to settle out with all the slopes involved. Most times it would be OK but on tight and demanding ares (slope) you could see the deck go through a lot of elevations. I am concerned with uneven cuts. At the same time, I am sure I would be able to determine the best way to mow the lawn and minimize problem cut areas, scalping, etc., with time behind the wheel. Never had a rider so maybe this would not be the case. I am just concerned with it being too big for the space and having to do a lot of cleanup with a WB. Am I over complicating things? Really do not want to spend that kind of money and not be able to use it on the hills as it must do a good job.
Seriously considering another WB. Either Honda with its superior much capability or a used commercial or high end residential. Anybody have any working knowledge of a Simplicity Pacer 1534? Saw one on craigslist. I believe it has a single hydro static wheel drive which may be a problem with the hill.
