fixitdad45
I'm working on a friend's Huskvarna mower which has a 24hp B&S v-twin. When I got it the engine would just crank and crank, no signs of starting. I found there was no fuel coming from the fuel pump outlet (hose to carb detached - nothing coming from pump when key turned) so I replaced the fuel pump. Same problem. Fuel dribbles at a steady rate from the fuel line from the tank which means the pump would get fuel so I'm thinking it's the pulse line.
I did a quick check of the 3" of pulse line that's visible to me outside of the valve cover and found no obvious issues. The mower is a 2013 model so not much time for dry rot. Rubber still feels nice and soft.
Part of me wants to pull the valve cover but I don't have a gasket to replace the current one with and I'm not sure if there's anything worth seeing in there after breaking the gasket. Can someone tell me what may be going wrong here please? Is there something lurking behind that valve cover that I really need to look at?
Thanks,
Scott
Thanks,
Scott
