Robots might work cheap but the machine costs a lot.
Better chance of some one diverting a scrap metal load of faulty plugs than some one setting up to make fake ones.
Back when I worked at Champion in my college years, there was 3 machines that made the spark plugs.
Each & every plug was tested as i came off the line .
Depending upon what the results were the plugs ran along the line then dropped into different boxes .
The best went into the bin for printing then boxing as individual plugs
the next best went to be printed & loaded into cards for the Leyland engine plant
The next best went to be blister packed for supermarkets
After that they go labled with a dozen different brands
The total failures went into a bin & were crushed then separated to recover the metal while the ceramics when to landfill .
After printing a clear glaze is applied so the names & grades can not be changed.
Even that machine was very expensive.
So perhaps a factory has been set up to take the scrap metal ones then print ,glaze , package & sell them, but the margin would be in the cents per hundred
